In Nitish's post, he asks the question,  "Can we think beyond SystemVerilog ...?"  While an interesting question, I think the more interesting question is,  "Can we think beyond constrained random?"
Constrained random comes with a fundamental problem. Randomization is intended to be uniform over time. In testbenches, we generally want one each of a large set of test cases (transactions and/or sequences). Uniform randomization does not generate one each. Instead it has a significant amount of repetition. In general, uniform randomization takes O(N*LogN) randomizations to generate N unique test cases. As a result, it repeats Log N test cases. Even for small numbers such 64 test cases, constrained random will generate more than 4X more test cases than needed - actual results will vary with the randomization seed.
What we need is an approach that only requires O(N) randomizations to generate N unique test cases. Generally these approaches are referred to as being Intelligent Testbenches. Indeed there are some tools out there that handle this. However, when we use a tool based approach we end up with a vendor specific solution. This removes one of the major benefits of a programming language based approach - encounter a issue (pricing or functionality) with one vendor and you can easily switch to another.
What we really need is a methodology for Intelligent Testbenches that is based on a standard language and works on numerous vendor tools. We have one. VHDL's Open Source VHDL Verification Methodology (OSVVM). OSVVM's methodology leverages the functional coverage you must write when you are using any randomization based approach. Intelligent Coverage™, the main randomization methodology for OSVVM, randomly selects a hole in the coverage and passes this to the stimulus generation process. The stimulus generation process uses this information, perhaps refines it using any methodology (directed, algorithmic, constrained random or file based), and then generates one or more transactions to accomplish generate the item that needs covered.
OSVVM works with any VHDL testbench and is particularly effective when coupled with a transaction based testbench. For me, VHDL and OSVVM are the step beyond constrained random and SystemVerilog. Maybe it is time we update VHDL's acronym to mean Verification and Hardware Design Language.
To learn more about OSVVM, see:
OSVVM is an open source VHDL library that is free to use (no license fees) and works with any simulator that supports VHDL-2008 (or VHDL-2002 with a little work).
What is currently in the OSVVM library is only the beginning. Over time, I will be releasing our generic scoreboard package, memory modeling package, and others. None of this is rocket science and it is all feasible with VHDL-2008. All of these are provided in our VHDL Testbenches and Verification - OS-VVM Boot Camp class
- The OSVVM Community Forum
- SynthWorks' OSVVM Blog
- OSVVM Webinar on July 18th (US time zones)
- OSVVM Webinar on July 18th (European time zones)
