            [0] => /forum/threads/spacex-wants-to-put-1-million-solar-powered-data-centers-into-orbit.24445/page-2
SpaceX wants to put 1 million solar-powered data centers into orbit
This is why everything comes down to launch cost per kg. The additional few percentage points in capacity factor doesn't swing the pendulum much. The whole concept seems viable and competitive even at >$250/kg, Musk's target is $10-20/kg. At $10-20/kg, the economics will be entirely in favor of orbital datacenters, just brute force with more batteries and solar panels. Until Starship is perfected, all of this is all speculation, but they have a good track record with F9 and I'm pretty sure they've considered all the stuff we're discussing here with their internal planning.
The FCC application calls for orbits from 500km to 2000km, the latter of which approaches MEO. There's more concern about damage from the Van Allen belt and energetic particles higher up, so one more factor to consider when going up. As for decommissioning and deorbiting, that's something they've been spending a lot of time and focus on since it directly impacts their future. I believe they've only had one, at they put it, dead as doornail satellite to date, the rest have been deorbited or are in the process of being actively deorbited. Their hall effect thrusters use only $10 worth of argon gas per satellite, their relentless effort to reduce cost is, quite impressive.
Not sure about active use times, there's a few charts out there, but the bigger problem with AI is the short peak-to-trough intervals on the order of milliseconds. This is problematic for the terrestrial grid and cannot be resolved without massive battery storage, but becomes less of a factor if all power will be provided through a battery in orbit.
Refer to this link for more on that: https://www.nerc.com/globalassets/w...ristics-and-risks-of-emerging-large-loads.pdf
Which is exactly what I said earlier, but which was voted down, possibly by the usual Elon-haters who want SpaceX to fail... :-(
(just for the record, I too hate Elon with a vengeance -- but that doesn't change the facts about whether space datacentres will work or not, though they do need Starship to get the cost per kg down)
If the satellites can be positioned in the orbital band over the poles which always sees the sun then the need for batteries disappears -- yes they'd then have to hop via other global-coverage Starlink satellites to get to worldwide users but this is already happening. The short-term power peak-to-troughs can be managed with small/light supercapacitors if no long-term (hourly/daily) storage is needed.
The objection because of the heat radiation/cooling problem doesn't look valid if the area needed for backside cooling is similar to that for frontside solar, which seems to be the case. To avoid heavy-duty power/cooling distribution it's likely that the NPUs will be distributed across the array and linked by low-power low-latency high-speed optical links, the same as those already proposed (e.g. CPO) for replacing copper in AI datacenters -- so you could end up with ~2kW panels (one per NPU?) with solar on one face and radiator on the other, with the hot bits sandwiched in between.
Still not guaranteed to happen though, even if the technology and economics both work the idea could be scuppered by launch capacity (though 4-8 launches per 100MW datacentre doesn't seem bad) or politics/regulation... ;-)
Is radiation hardening a problem?
Maybe, maybe not. I know that the DSP chips inside the optical modules used for the inter-satellite laser links are standard commercial N4 CMOS with no special hardening or testing, and don't seem to have any problems. Presumably any critical satellite control systems need aerospace-level redundancy (e.g. like Airbus use for flight computers) to avoid program/data corruption from bit flips, typically these use triplication and majority voting so if one CPU goes wrong it gets ignored and then rebooted. Comms links are always error corrected anyway.
What happens to protect against bit flips causing errors inside the data center itself is another issue, but I guess precautions against this are needed on the ground anyway -- maybe some extra duplication or error-checking is done?
5 year life, for inference work, seems it shouldn't be a huge problem, here's the following from Google, regarding radiation with simulations using their TPUs, with 10mm aluminum shielding in LEO:
what about memory like HBM?
HBM was the most sensitive, the error rate is in the attached snippet. Good enough for AI inferencing. This was based on 10mm aluminum shielding, again, all of this comes down to the actual launch per kg costs, if costs go down, just add more material for shielding. The Google Suncatcher white paper mentions $200/kg as the inflection point where LEO costs are comparable to terrestrial datacenter per kw of compute, I used $250/kg to err on the side of being more conservative given there are still some uncertainties to consider, but somewhere between $200-$500/kg will be the point where LEO starts making sense and the lower you go, the more LEO makes sense. The white paper mentions the floor to be $8/kg, the best guess estimate for the baseline cost of the methane + LOX for Starship, so actual launch cost will come down strictly to how many times the launch vehicle can be reused. Their upper estimate is $460/kg for Starship even without reuse so even without reusing the launch vehicle...it could be practical.
For memory, might it turn out to be better to add more robust ECC than heavier shielding?
IIRC Starship is targeting $100/kg in the not-too-distant future, which makes an LEO datacenter cheaper than terrrestrial -- assuming you can launch enough mass, which also doesn't seem unachievable with rapid Starship re-use.
HBM already has some ECC built-in, I'd imagine a little additional material for shielding would be simpler cost-wise than redesigning the architecture of the chips specifically for LEO use. Then again, I suppose if the volume grows sufficiently to the point datacenters in space become the norm, then having the industry design the memory specifically with additional ECC to withstand LEO could end up being the standard! I guess we'll find out in the next few years where we'll be on cost.
It'll be critical for the tech giants for economically viable alternative launch systems to be available, otherwise, SpaceX can take advantage of in-house launch costs, pricing the competition out. They currently charge customers upwards to $4000/kg for F9 while for their own Starlink network, they can launch those at cost, perhaps as little as $1000/kg now. SpaceX getting Starship cost down to $100/kg, if they can get Starship to work, that's easily viable. The question is, what will they charge for others to use the same rockets? New Glenn is the closest alternative outside of SpaceX and it's only launched twice as of now whereas F9 has launched nearly 600 times. The Chinese are working rapidly to make reusable launchers but pretty sure western aligned tech companies won't be using those. Nobody else has reusable super heavy launch vehicles on the horizon, if space datacenters become a thing, SpaceX is going to make a killing.
There's no need the change the memory architecture, additional ECC with low overhead can easily be done at the memory interfaces of the AI ASICs, like concatenated FECs in communications which have to deal with high BER. If hard HBM failures become an issue rather than just bit errors, redundancy could also be added -- which it probably is at the system level anyway since there's no repairman in space.
The whole point of Starship is to drop launch costs to LEO by an order of magnitude, if other companies have decided not to compete with SpaceX to do this then surely that's their problem? How is this any different to what Intel did, or any other companies who dominated an industry by being way ahead of everyone else?
You could say it's not fair that SpaceX are using Starlink to push their launch volumes up massively and justify Starship in the first place -- or at least, pay for the development -- but again there was nothing stopping other companies doing the same thing, it's just that SpaceX was the only space launch company willing to take the risk and do radical things that all the naysayers said were either impossible or unfeasible or financially suicidal.
And regardless of how much people (including me) dislike or hate Musk nowadays, none of this would have happened without him.
