            [0] => /forum/threads/lisa-su-agentic-ai-could-put-more-cpus-than-gpus-in-compute-nodes.25063/
Lisa Su: "Agentic AI could put more CPUs than GPUs in Compute nodes"
Xebec
AMD's Lisa Su...We certainly see the movement towards where in the past, the CPU to GPU ratio was primarily just as a host node in like a 1:4 or 1:8 configuration node, now changing and getting closer to a 1:1 configuration or even -- you can even imagine if you get lots and lots of agents that you could have more CPUs and GPUs...
.. This may further explain the (server) CPU supply shortages.
